Ls motor noise HELP!!
Old 07-22-2014, 03:23 PM
Shreddedz28's Avatar
Default Ls motor noise HELP!!
Does not sound internal, oil pressure is good. It squeaks and the motor shakes pretty good. I'm thinking motor mount but any input on what you think it could be would help a lot. Thanks http://youtu.be/kfT1p9Uc-mE
Old 07-22-2014, 03:31 PM
Always2Slow's Avatar
Check under the car that doesn't sound motor related. Check your accessories, check your mounts, check the exhaust, check heat shields.
Old 07-22-2014, 03:46 PM
It is not the headers nor the y pipe connected. The only thing I could think of would be the motor mount because the noise is only coming from the passenger side and the motor tends to move around a lot at idle.
Quick Reply: Ls motor noise HELP!!
