Shifted 3-2 at the track...what could I have broken?
Old 05-20-2004, 06:57 PM
Deividas93GT's Avatar
Default Shifted 3-2 at the track...what could I have broken?
Went from 3-2 in the TA and ran a 14.0/76. 1/8th mph was 85 and after that run every run with similar driving netted 81 mph. What can cause that power loss? What should I check for? Compression test? Bent pushrod? Plugs?
Thanks
Old 05-20-2004, 07:03 PM
The Guy in MY 99TA's Avatar
look for several bent pushrods and excessive tapping noises!
Old 05-20-2004, 07:07 PM
Thanks, I'll check them out.
Old 05-20-2004, 07:15 PM
mr_nate's Avatar
pushrods should be the first thing you check, they bend reeealll easy when mis-shifting..
Old 05-20-2004, 07:29 PM
taqwache's Avatar
thats exactly what happen to my car the first time i let my wife take it down the track. luckly nothing happen to it and i was able to finish the race. of coarse i did not let her race it again that time. anyways to answer your queston, like others said, i bet you have some bent push rods.
Old 05-21-2004, 06:36 AM
JoeDirt's Avatar
A buddie missed the 4th and hit 2nd in his SS. We pulled his pushrods and about 75 % were at least a little bent with about 3 or 4 giving a pretty nice wobble/hop. We were going to swap in my stock pushrods but they were almost as bad and Ive never missed a shift . Stock pushrods = week me thinkie . We ended up just grabbing the best of the buch and patching it up but it wasnt easy getting 16 good ones out of 32
Old 05-21-2004, 09:06 AM
SSCamaro99_3's Avatar
Most likely is pushrods, but valves and spun bearings are also possibilities.
