5.3l CAM ?'S
5.3l CAM ?'S
I talked to a guy at comp cams and he said this cam will work good for my 2007 impala ss and he said I will need to upgrade my springs and trunion. what do you guys think?
Brand New COMP Cams XFI AFM Hydraulic Roller Camshaft GM LS-Series Gen IV V8 Applications with 1-Bolt Core, Active Fuel Management & W/O Variable Valve Timing. Part #646-431-13.
Cam Specs & Description:
Valve Lash (IN/EX): Hyd / Hyd
RPM Range: 1600-6300
Advertised Duration (IN/EX): 275 D / 286 D, 262 N / 274 N
Duration @ .050" (IN/EX): 212 D / 224 D, 210 N / 222 N
Valve Lift w/1.7 Ratio Roller Rockers (IN/EX): .500 D / .500 D, .500 N / .500 N
LSA: 115°
Cam Description: Great all around torque for trucks and other heavy applications; across the board improvements power over stock AFM cams.
LSA: 115°
You'll want to upgrade your springs to a stiffer set and upgrade the rockers with Comp's trunion upgrade kit. Possibly lifters, ported & polished pump, and a chain as well since you'll be opening it up anyways. Consider new injectors for the flow.
$629 for the basic kit.
http://hubbardracinginc.com/product/complete-cam-kit/
-Custom Comp Cam (you choose the size you want)
-BTR Dual .660 valve springs with steel retainers
-BTR Chromoly Push Rods
Then...
-Ported LS6 HRI Oil Pump - $85
-Delphi LS7 Lifters - $119
-LS2 Timing Chain - $42
all from www.hubbardracinginc.com or Hubbard Racing Inc.
Then...
When you said choose what size cam I want,I would have no idea.i just want a basic kit like you said but I don't know what size cam to get if you could tell me.
I just want my car to be pretty loud and be anywhere from 300-350 FWHP.I only want to spend $1000-1500 on parts.
Mods I have don't right now are a CAI cold air intake,custom cat back exhaust res delete with no cats,and a ECM/TCM tune by vector motorsports.
It's my daily driver so I don't want nothing crazy to where it could blow up lol.
