torquing down rocker arms question?
Old 05-21-2004, 11:45 AM
amadeus's Avatar
Question torquing down rocker arms question?
I did the dreaded 3-2 shift, and i hear a slight ticking. So today i plan on pulling pushrods and replacing etc. My question is am I suppose to use loctite and re-torque to 22ft lbs? Im hoping its only pushrods, anyways thank you.
Old 05-21-2004, 11:50 AM
badls1's Avatar
I wouldn't use loctite on the rockers. 22 lbs should be fine. check all the rocker arm make sure its okay if you have an bent pushrod.
Old 05-21-2004, 12:03 PM
LS1TECH Sponsor
Steve Burger's Avatar
With ported heads blue locktite seals the threads so oil does not leak into the ports. If stock heads then no.
Old 05-21-2004, 12:23 PM
amadeus's Avatar
thanks guys
