best heads to buy or should I port and polish.my stock ones???
Here you go OP. AI can take care of you and make your stock 241's shine.
http://www.advancedinduction.com/LSX...RGMLS1Head.php
OP look at it like this...let's just say $1200-$2600 for mild to wild heads for your ride. For double the price the high end heads might get you 20 hp over the cheaper ones. Is it worth it?? That's up to you
Exactly, people get wrapped up in dyno numbers all the time chasing 10-20hp. For a street car, not worth it imo. OP, how much power do you wanna make? Heck, the right cam and a set of stock 243's will make good power and not break the bank either. Low 400's all day.
Lots of options what to do?
Want vs afford
Problem with going through used heads is porting and springs are part of it.
If they guides are worn at all you can bet the valve job could be compromised. Get a vj without doing guides youre back to ground zero...and risking a failure. Thats an unknown potential repair/cost untilthey come apart. May get lucky may not.
btdt
Save and get the new stuff if you can.
Want vs afford
btdt
Want vs afford
btdt
Want vs afford
btdt
