Springs for TSP 231\237 cam?
LS1Tech Premium Sponsor
We've been running the 231.237 with 918s without a problem If you don't mind the extra $$$, you might also consider the Crane or Patriot double spring packages.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
when i do my TSP 231/237 cam swap i am going to be going with the comp 921's(dual springs) with titanium retainers just alittle more insurance with a that big of a cam.i have heard of the 918s letting go and dropping valves and that is when you engine goes BOOM!!
thunder racing sells the comp 921 spring kit-P/N 63-26921-KIT(www.thunderracing.com)
I would recomend spending the little extra $$ and getting either Patriot Gold springs, Crane, or Comp 921. The 918's will work, but a little to close for comfort for me
