MMS 220 Build for "Ghost Hawk"
#122
KOOKs will be LOUD just an fyi lol. They both seem to be nice systems. The 2.5" on the hooker will still be plenty for your setup. It's also cheaper than the kooks by a good bit but will need to be modified to fit LT's. OTOH kooks will bolt right up but will be heavier, louder(if that matters) and needs a panhard bar relocation to clear the axle. there is a couple exhaust clips of the hooker in the external engine thread and to me it sounds nice.
based on that I would give HEAVY consideration to the hooker system but if you end up liking the kooks better then go for that.
one other thing. if you havent bolted the intake down yet go try and find some heat insulation that an adhesive backing and apply it to the bottom of the intake. it helps keep heat from the valley and heads off the intake. I did this on a recommendation from a tuner and noticed that my intake is much cooler to the touch after driving.
#123
Since this is a no excuses build, I wouldn't hesitate on the Kooks 1 7/8" headers and 3" true duals. I've never seen another exhaust out perform it. On my stock ls1 I went from 290 rwhp to 331 rwhp with the Kooks and a cold air kit. Sure that's an apples to oranges comparison bit imagine the gains you'd see over the Hooker setup or your current setup. Plus the sound is amazing. Doesn't have that raspy y pipe sound. It sounds like a real muscle car.
#124
Moderator
Received 1,836 Likes
#125
Moderator
#126
Probably so. I think you're spot on. I believe the x pipe and 3" exhaust are perfect for your build. You've already got good headers, plus a 3" exhaust has more *****. The Kooks mufflers are just straight through bullets... so there free flowing... and loud.
#128
Moderator
So the crossover got lost in shipment. New one being shipped. So frustrating. Car should have been on the rollers by now.
#129
Just thought I would mention, my 220's just came in today. Got them bolted up and started measuring shims. Turns out the .093" I got from Amazon were all about .001 from each other. The YT shims on the other hand were all over the place. After much sanding on 320 grit and glass I ended up with a combo of .137" +/- .0005 and a nice, narrow and centered wipe. Using a cometic .040" HG and Johnson 2110 lifters netted me a pushrod length of 7.522". As it turns out, Manton will make you a pushrod who's length is 7.522". Sweetness.
I just hope the rockers will clear the valve covers....
#130
Moderator
Just thought I would mention, my 220's just came in today. Got them bolted up and started measuring shims. Turns out the .093" I got from Amazon were all about .001 from each other. The YT shims on the other hand were all over the place. After much sanding on 320 grit and glass I ended up with a combo of .137" +/- .0005 and a nice, narrow and centered wipe. Using a cometic .040" HG and Johnson 2110 lifters netted me a pushrod length of 7.522". As it turns out, Manton will make you a pushrod who's length is 7.522". Sweetness. I just hope the rockers will clear the valve covers....
#131
Nice build, very interested to see what power it puts down. I'm thinking of doing a very similar build if my car stops breaking long enough for me to save some money.
#133
I am working on the same build, different cam though. This is a first build for me so I am waiting on my friend to free up time so he can help out. I am lucky that mine is out of a car and I am doing a stock rebuild on the bottom end also. My two main points of concern will be PTV clearance and Pushrod lengths. I now know what to look out for with the shims, Thanks.
I still have to get the chassis ready so time is not a factor and I am getting a lot of good reference material from your builds.
And I agree, Tony is a great help with this entire process.
#135
Moderator
#137
Moderator
Ok so I should have the crossover today. When I do the initial start up I'll be in SD (disconnect maf). Any other concerns for initial start up? I'm sure it'll take a bit to learn the idle. I'll disconnect the cracker, power on for 30 seconds, then off and reconnect to start the learn cycle.
I've backed some timing out for safety.
I'll bump the starter to move some oil around without the fuel pump running.
Anything else I haven't thought of please speak up
#139
I feel cranking it over for 30 seconds (or more) is worse than firing it up with the speed immediately kicking the oil pump in gear. Oil is some slick **** (that's its job right....LOL) and even residue oil on the bearings/crank will protect it from the start up RPM until the pump kicks in immediately after due to the engine speed kicking it into high gear.
We run into this on the engine dyno alot with new motors.....its a PITA at times. Our new trick is to put some positive crankcase pressure in the engine from the valve covers or breather helping to literally push the oil into and up the pick up till it reaches the pump but a little goes a long way.....5-10 PSI is all you need and that helps the engine cranking speed actually get it primed but I'm discussing a new engine here which I believe are more temperamental on start up regarding getting the oiling system filled and primed.
Darth....spin it for a bit without the plugs....it may prime quickly having run not that long ago....if that doesn't work just fire it up and you should be golden assuming you didn't fubar your oil pump O-ring or anything sill like that.
-Tony
PS.....If the race to post the first results were a horse race it would be a horse nobody is watching that actually wins it flying by Unit and Darth in the back stretch for the coveted ring of roses at the finish line.....LOL It would be funny if someone out of the blue posted numbers this week.....LOL
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
