I need help with head and cam selection (pretty please)
Old 06-07-2004, 01:50 AM
Elec87's Avatar
Default I need help with head and cam selection (pretty please)
I am curious about what peoples head and cam combos are yeilding on stock bottom ls1's.
Here is what I have
1999 ls1 mac midlengths
12 bolt 4.10 gears
lid and no cats
I would like to see this car run in low 12's possibly 11's with very mild manners
I have options to use a set of 5.3 heads and a set of stock heads. I would like to get some port work and a mild cam, I want good power from this car but don't want to sacrifice drivability (road trips).
What is the max lift you are allowed with a stock headed combo, What would be allowable on a 5.3 combo. I do not want to run into and valve interference problems.
Sorry about all the questions This is my first ls1 project and I am very anxious to move on it. Thanks again guys.
Old 06-07-2004, 02:37 AM
SSactionLs1's Avatar
thats it? ok then anything over a 220 and some 5.3"s should get you there no probs.
Old 06-07-2004, 04:12 AM
distortion_69's Avatar
You could probably do low 12's with nothing but some slicks and a good clutch with what you have thus far. However, for 11's I'd do like the above msg says.. budget heads, tr220 or larger depending upon your tolerance for a rough idle. You could actually just ditch the heads all together and do high 11's cam only with a number of cams. My favorite being the FM13.
Peace,
Josh
Old 06-07-2004, 05:27 AM
Elec87's Avatar
Do you have specs on that cam? I want to be able to run it with the nittos that are on it right now. I just want my car to be able to somwhat repeat what it does on the strip on the street. Maybe this could be a plan. I was just looking at prices for retainers and springs, ouch they gouge you on every little bit for these cars. So far the car has run a best of 13.26 at 105.
Old 06-07-2004, 05:31 AM
jrp
SN95 Director
jrp's Avatar
what cam? the tr220? thats 220/220 .553/.553 112 or 114lsa. you can get the manley spring kit for 178 and thats with springs good for .600 lift and tit. retainers.
Old 06-07-2004, 08:51 AM
MyLS1Hauls's Avatar
Its going to be tough to go 11s on Nittos with a 6spd and keep "mild manners" You either need lots of power, a great launch, or both.
