Parts to convert to solid roller?
Back in the staging lane
I currently have a 422, LS6 stage 3 heads. What all parts/modifications will I need to convert to solid roller? Just want to make sure I've got everything accounted for. Thanks.
What do the solid tappets for ls1 look like? ie SBC uses a link bar to keep them from rotaiting. Is there an ls1 specific solid tappet that works with the plastic retainers? Or does the block need to be machined to accomodate a mechanical lifter?
I have been curious about this for a while I just never posted up before.
Thanks,
Brad
Thanks,
Brad
I was actually talking to a guy the other day and he said they bore the lifter bores and puts bronze(maybe) sleeves in them for less wear.
Last edited by The Guy in MY 99TA; 06-19-2004 at 11:08 AM. Reason: didnt want to give out information that a sponsor uses
I've got Crane 10510 lifters in my motor. Standard solid roller lifters for hydraulic roller blocks. My lifter bores were not bushed, but if you go above .650 it's recommended.
Other than that, Mustangeater's list is correct. Definitely need a stout set of valvesprings, Super7 locks, 3/8" pushrods, and some clearancing on the head to allow the pushrods to clear. May or may not need new (longer) valves, depending on valvetrain geometry & spring selection.
I'd call Futral or Thunder.
