New build coming soon...
TR6 is fine, but like HCI2000SS mentioned the BR7EF is what is recommended when you add the 100-150 shot of spray to the car. I have run the BR7EF on both n/a and power adder applications with great results.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
#33
That breather looks like a nice piece. And the shiny coil brackets with the wrinkle black valve covers looks badass. This is coming together quite nicely, keep it up.
#34
Looking good. Looking forward to seeing the final results.
__________________
#35
How well does that breather fit in the valve cover? I have the Mighty Mouse -12AN fitting that goes in the fill cap location, its pretty loose and leaks oil.
#40
Installed my original street twin after getting it back from them for a full rebuild. Just installed trans and tye driveshaft etc... Went to go for a test drive, but car went nowhere. It can only go in gear with clutch pedal depressed (obviously). But when i let go of pedal, it does nothing. Its as if the clutch is t engaging... Does anyone have any thoughts on this?
