new to internals...where do i start?
i have never really considered going internal, but bolt-ons can only go so far. any suggestions as to where ic an start. i would like ot stick with the same heads, but like the idea of a cam. maybe some new springs. i dont want to get to radical but would like to see my options.
open to suggestions
J
open to suggestions
J
If your not wanting to go to radical something like the TSP 231/237 cam would work pretty good along with the Patriot Gold springs(<---None better right now IMO). You will want a set of hardened pushrods and should probably look at a set of aftermarket rockers, I say this because the factory ones have a tendency to randomly spill their needle bearings. While your doing the cam you may as well replace the oil pump with a ported ls6 one and replace the timing chain with a rollmaster double roller, these are known to go out on the 98/99 cars. Good luck.
-Sly
-Sly
-Sly
-Sly
could i get a little but more outta of doing just heads...?
J
