Cam intended use?
Cam intended use?
Help me out guys.
Comp Grind
Gross Lift : Intake .613 Exhaust .613
@ .006 289 291
Valve Timing Open Close
@.050 Int 8 BTDC 46 ABDC
Exh 47 BBDC 9 ATDC
@ 109 Intake Center Line
Intake Exhaust
@.050 234 236
Lobe Life 361 361
LSA 109
What do you think this would work well in, or what would it take to make this work well?
Comp Grind
@ .006 289 291
Exh 47 BBDC 9 ATDC
Intake Exhaust
@.050 234 236
Lobe Life 361 361
LSA 109
Maybe I should have phrased it differently. Should this cam have enough PTV clearance on a stock bottom end LS1? What about with 799 heads that are milled 10 thousandths?
Thinking of using it along with a TPIS 90mm LS6 intake, 799s are hand ported and flow as follows
Intake Exhaust
200..159 117
300..210 159
400..254 169
500..281 187
600..296 203
PSI 1511s, Manton 11/32, 90mm TB, 1 3/4 LT into Corsa. Car has a 3200 Vig currently. I'm not opposed to re-stalling it higher and possibly switching to 1 7/8 TSP with TSP true duals....
Intake Exhaust
200..159 117
300..210 159
400..254 169
500..281 187
600..296 203
that intake valve closes pretty late. i'd check it with clay to be sure.
i'm no cam guru, but the lift and duration seems like it would be okay with your car. it was probably intended for something a bit lighter with that lobe sep.
but take that with a grain of salt please. like I said i'm no guru, i just saw your post had no replies and I thought i'd get the ball rolling
