piston ring gap question
Built a lm7 5.3 all new bearings ect, i did not gap the rings went with stock everything. If i want to spray it with a 150 how much should i gap the rings? Probably seems like a dumb question but i want everybodys input thanks
thanks for the input , i wasnt going to even worry about it but changed my mind and going to gap the 1st and 2nd ring at .030
Super Hulk Smash
That's a lot of gap for a small nitrous shot.
I'd do .024/.026 at the max but more likely .020/.022.
Wiseco has a handy little chart as well on ring gaps:
Multiply your bore size in inches times the value on the table.
For small nitrous and 3.78" bore it works out to .019"/.021" or so. Hence why I'd probably open it up a smidge and go .020/.022.
Code:
Top ring 2nd ring Oil rail Most standard engines 0.004 0.005 0.015 Nitrous Oxide 0.005 0.0055 0.015 High performance racing 0.0055 0.0053 0.015 Racing with Nitrous/ Turbo 0.006 0.0057 0.015 Blower / Forced induction 0.007 0.0063 0.015
