Review my build plans
Old 03-15-2017, 12:38 PM
98RedBird's Avatar
Default Review my build plans
Hi All,
I've got a 2000 Camaro that I'm wanting to do a little work on this spring, I've put a tentative list together and was wanting you guys to give it a look over to see if there's anything I'm missing, or if you would have any other suggestions.
Car is an A4 with about 90k on it.
Overall goals are a low 11@120ish.
FLT Level IV Trans
Yank/CircleD 4k Stall, cooler, gauge
Torque Arm, Panhard Bar, LCA's
3.90's
Nitto 315 DR's
TSP 1 7/8 LT's TSP Duals
PRC 225 as cast heads
Torquer V4 (or something simliar)
Morel 6504, same as 5315
Will be running an LS6 intake for now, don't have money for FAST setup
Racetronix Fuel Pump, 42lb injectors
U/D pulley, Something like a chris1313 ram air
Open to suggestions! Thanks guys.
Old 03-15-2017, 02:43 PM
JTtransAM's Avatar
How often do you plan on taking it to the track? Is it your DD?
Old 03-15-2017, 02:53 PM
TXZ28LS1's Avatar
Looks good... i would run PRC 227 heads and TSP 233/239. Its the cam i am running and about the biggest i would run.
I run livernois motorsports stage 3 LS6, TSP 233/239, circle D 5C, TSP 17/8, and an ls6 intake. So mods would be similar to your build.
Quick Reply: Review my build plans
