Rough idle, random RPM spikes in S-10 swap
Well got the trans issue sorted out, and now a new issue has shown up.
First the oil pressure gauge quit working (45 psi to 0, not moving). This was an easy fix, pinched pink wire. Gauge works fine now.
Then the engine started acting goofy. Getting a spike in RPM to 3000 range, then drops to 900, then 550 and eventually dies. Restart and same thing over again.
Diagnosis is pointing to the throttle body as the reader says “No codes found”. So am I looking at the TPS switch, IAC, complete throttle body or an air leak? This engine was running fine and taking throttle. Idle of 750 rpm.
I had to tear down the front end to pull the trans and replace the bell & converter. I don’t see anything obvious, like an air tube that is leaking unregulated air into the system.
Another is that the truck is running rich. Like burns your eyes rich. So, I think this may also be related to rough idle and other symptoms.
Combo: ’99 5.3, 2002 LS1 cam, ’98 F-body manifolds into a Y-pipe. Otherwise all stock
Trans is a 4L60e original to the S-10. Going to use it until……
So I need some ideas.
Moderator
Received 1,852 Likes
Running rich will cause idle surge badly. So before you start chasing throttle stuff, check your oxygen sensors and wires and check your exhaust for leaks. Very possible something got amiss in the exhaust after dropping tranny.
Exhaust & stuff
Well the exhaust is sealed up. Only possibility is the short pipe at the y-pipe to cat. The possible leak would be after the O2's (like 6-8 inches past the O2 on the pass side).
I did replace the IAC valve and TPS last night, no change. These were original to the engine, figured that this will eliminate obvious issues with possible failing sensors.
Truck isn't pulling any codes, so an unplugged O2 seems to not be very likely, but I will check the pass side again to be sure. I have 2 more new O2's if that proves to be what's wrong.
Fixed
Well 3 sets of ears are better than just mine. Got the issue fixed now. It was a missing gasket at the EGR inlet. I couldn't get in front of the truck quick enough to catch it. Pulled the spare off the shelf and voila, perfect idle and takes throttle again. Tonight I will finish up the punch list and get it aligned. Should be on the road next week.
Moderator
