Question for the cam gurus (pardone my ignorance)
Why would you use a lobe that was slow as opposed to a lobe that is aggresive? I was always taught to get ramps that were as fast as possible to get as much air in the cylinder as possible and then slam the valve shut. If the user were using in-efficient heads wouldnt this still apply but adding duration to pop it open and hold it open longer then closing it as fast as posible? Would you still be leaving some on the table power wise by using a slow lobe?
Hope this is clear as i drank a few beers
The reason why i ask is because in teh Cam discussion thread IIRC i seen Cstraub say under certain conditions he uses slower lobes and I was wondering what the significance of that would be
Induction wants in and exhaust wants out. The LS1 suffers from extremely good exhaust. . .IMO its to good. Depending on what you have induction wise, the lobe could be on could not be aggressive to get the task done. As far as the LS1 exhaust, the lobe needs to be easy because the ports flow so good.
No guru here. . .just enjoy what I do.
Chris
Chris
Chris
Chris
