Oil on spark plugs?
1 Post
Is the oil on the threads or actually on the electrode?
Either way.. if it's on the threads, I think that you just have an issue with your PCV system letting oil down into the cylinder..
Check into an AMW Catch Can -------->
You're probably sucking a lot of oil through the PCV system. Pull off the air cleaner lid and bellows and look in the throttle body. Is there a lot of oil in there? If so, get a catch can and hook it into your PCV system.
Other than that..is the engine stock? If stock, how many miles on it? If the car has aftermarket heads it could be pulling some oil around the rocker studs. May need to put some silicone on the rocker stud threads. If every plug is oily it's more than likely PCV related.
Originally Posted by SSLS1
where is the pcv valve located?
http://www.hovis.cc/Firebird_HTML/pcv_mod.htm
a lot of info on what it is, how it works and one of the options to deal with it. If the probelm is serious, you will probably need a catch can.
