HELP, my car keeps spitting up
Old 07-08-2004, 08:00 PM
slavic's Avatar
Question HELP, my car keeps spitting up
Here in Oklahoma it has been reaching the mid nineties the last few days and when I get done driving my car the radiator makes gurgling noises and fills the over flow tank which overflows around the cap.
Any idea WHY?!
THANKS!!!!
Old 07-08-2004, 08:31 PM
CRASH 02's Avatar
Josh,
Are you sure your fans are coming on? What is your temp gauge reading? With your car up to temp and without the A/C on see if one or both of the fans are spinning. They should both spin at all times with the A/C on. After that, I would check your radiator cap. If it isn't holding the correct pressure then the fluid will flow into the overflow.
Old 07-09-2004, 03:41 PM
slavic's Avatar
Thanks for the reply crash, long time no see, I checked what you said and have come to the conclusion that I am just low on fluid. I had it at the dealership a couple weeks ago I guess they did not fill it up all the way.
BOB MOORE
Old 07-09-2004, 03:55 PM
94form2000z's Avatar
That or they didn't bleed the air out of the system. I played hell with mine once before.
