oil pressure?
oil pressure?
Is there a way to tell you are getting oil pressure other than the factory gauge? I did a head and cam install but also installed new gauges which required removal of the needles and not sure the neddle is where it is supposed to be. After starting the engine the needle did move up but not sure if it was enough. Any suggestions?
