P/V Clearance ? with this head/cam combo
Old 07-22-2004, 08:31 PM
ArcticFormula's Avatar
Default P/V Clearance ? with this head/cam combo
Currently have a 02 Formula with just lid and catback, and am saving for heads/cam.
Have definitely decided on 205 AFR heads (want stock compression so I guess the 66cc) and use stock type gasket. Anyway now need to choose a cam, and was thinking having one custom made to these specs: 220-220 .580-.580 +4 advance xe-r lobes. Would I have P/V clearance issues or be out of the safe zone so to speak which is what (0.04?), fwiw don't plan on changing the stock shift points. Trying to learn here. Thanks in advance!
Old 07-22-2004, 10:49 PM
44mag's Avatar
its always good to verify it but their are people running much larger cams than that with no problems.
Old 07-23-2004, 01:13 AM
PREDATOR-Z's Avatar
PM Tony Mamo for any qusetions on AFR. Who knows better than the person who designed them?
JFYI Initially I wanted to go with a 216/220 Comp (Have it laying around for awhile) and Tony was wondering why I wouldn't use a more aggressive cam with my 62cc AFR (Stil waiting for delivery), like a 224/.581 or so.
I followed his advice and got a MTI Stealth 2 224/221, .576/.581 116+4lsa but decided to go with unmilled heads so not to have any p-rod 7.40 & (non adjustable) rocker HS preload problem.
