SLP Roll Master Timing Chain
Old 07-23-2004, 09:08 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Default SLP Roll Master Timing Chain
Any have the install instructions for it? TIA.
Old 07-23-2004, 09:54 AM
PREDATOR-Z's Avatar
http://ls1howto.com
look either under cam install or H/C install
Old 07-23-2004, 10:03 AM
ls1290's Avatar
I took a lok there, it only mentions how and when you should replace the chain. It does not mention anything about how you remove/install the new gears for the crankshaft. That is what I am interested in. Can you use just a pullie remover to take of the gear? What do you do to install the new gear onto the crank?
Originally Posted by PREDATOR-Z
http://ls1howto.com
Old 07-23-2004, 10:08 AM
PREDATOR-Z's Avatar
Then let a shop do it.
Old 07-23-2004, 11:10 AM
fastsspr's Avatar
If you go to the head/cam change article you can find the process you looking for!!!
