G-Force 205CC AFR Head Flow #'s Inside!
Old 08-11-2004, 12:37 AM
Ben R's Avatar
Default G-Force 205CC AFR Head Flow #'s Inside!
These are the cylinder heads going on our shop car this next week. We bought them as rough castings (No CNC Porting from AFR) from AFR a couple of weeks ago and turned them over to GTP to have them worked over. After about a week we got the heads back and these are the results!
Head Info:
2.02/1.60 Valves
Flowed on a stock bore
Lift .200 .300 .400 .500 .550 .600 .650 .700
Intake 139 193 245 293 310 320 322 325
Exhaust 110 156 199 217 223 227 229 230
Those numbers seem to be pretty good considering that was the first pair GTP has seen and hasn't had a chance to experiement with them. These heads were flowed on both an SF-600 and an SF-1020. The numbers for both flowbenches were exactly the same.
These heads have the smallest ports of any Stage 2 LSX head I've seen. The velocity numbers have got to be super high. These heads are going to make a lot of torque.
We're going to have the shop car up and running the next week, so we'll post back with the dyno numbers, but we're looking for an AWESOME torque number, and horsepower in the 455/460 range on a stock shortblock. I doubt we'll post the nitrous numbers though.
If you're interested in a set of these heads, shoot me or Mike TexaSS a PM and we'll get you taken care of!
Old 08-11-2004, 12:46 AM
pdd
pdd's Avatar
Old 08-11-2004, 01:08 AM
99ssleeper's Avatar
I thought AFRs arent supposed to be ported?
Old 08-11-2004, 01:20 AM
jermstyle's Avatar
Guess they are...
Old 08-11-2004, 01:22 AM
Ben R's Avatar
You can have these heads CNC ported by AFR if you want, but we chose to buy the bare castings and have somebody else hand port them. The results are looking pretty good so far.
Old 08-11-2004, 06:21 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
What kind of port voulme did you end up with?
Old 08-11-2004, 06:58 AM
Camaroholic's Avatar
Nice, those are better numbers than both of the GTP LS6 SII sets I've seen. (my own included)
Old 08-11-2004, 07:23 AM
OWENMUSTANG's Avatar
[QUOTE=J-Rod]What kind of port voulme did you end up with?[/QUO
i also would like to know!
Old 08-11-2004, 07:37 AM
CHRISPY's Avatar
Yep port volume info needed please!! Also what was the final chamber size
Old 08-11-2004, 11:37 AM
Ben R's Avatar
The chamber size is very small. I'll get the exact port volume and post back.
Old 08-11-2004, 11:48 AM
MUSTANGEATER's Avatar
Very nice numbers, did Craig himself do these?
Old 08-11-2004, 01:10 PM
Ben R's Avatar
I just got off the phone with Craig and he said the port volume is 206cc's.
Here are some pictures of the heads that we got this morning.
Enjoy....
Old 08-11-2004, 01:12 PM
Ben R's Avatar
Sure did.
King of Pigskin Knowledge
BuckeyeROC's Avatar
320 cfm @ .600" with a 206cc port???
Old 08-11-2004, 01:14 PM
Ben R's Avatar
The chamber size on these heads is small for our application, but I BELIEVE it's 53CC.
Old 08-11-2004, 01:18 PM
BuckeyeROC's Avatar
Wonder what you guys can do with a 225+cc port???
Old 08-11-2004, 01:23 PM
STF Veteran
99-LS1-SS's Avatar
Those are some good numbers. What will a set cost?
Old 08-11-2004, 03:02 PM
Ben R's Avatar
Final pricing has been set. PM me for more info!
Old 08-11-2004, 04:23 PM
Mirek's Avatar
Would a 52cc chamber even run on pump gas ?
About what compression are you at at that point ?
Old 08-11-2004, 04:35 PM
XIII's Avatar
Tell Mike that I would be happy to bring my car back in for yall to test those out on till you get a shortblock in the Vette LOL. Just cause I am a nice guy and all.
