Best High Flow Oil Pump vendor?
Old 08-29-2004, 02:25 PM
MelloYellow's Avatar
Default Best High Flow Oil Pump vendor?
Am going to purchase a high flow oil pump.
Anyone have a rec for best vendor/product?
Are they all the same? Mild porting + a spring shim?
I think my MTI bearing clearance is a bit loose and would like to see more pressure.
TIA!
Old 08-29-2004, 03:19 PM
Scalpel's Avatar
I don't think anyone makes an aftermarket higher volume pump.
I know vendors will port the inlet of the stock pumps or a neglible increase in volume however I feel the greater increase in PSI is due to the vendors who also SHIM the relief valve spring.
Someone mentioned that Melling was making an oil pump for the LSX powerplant however I haven't seen any info on it, yet.
Old 08-29-2004, 03:43 PM
MyLS1Hauls's Avatar
Shimming the relief spring will only increase peak pressure and will do nothing below 65-70 psi. It will not allow more volume, which is what you need to keep the pressure up. I'd try running some thicker oil like a 10W40, maybe a little heavier.
Old 08-30-2004, 12:15 AM
Thx. Was thinking same thing.
Switching to 10W40 this week.
May go up to 50W if needed.
Old 08-30-2004, 12:57 AM
Mooobunnny's Avatar
Do a search for it. It is out and available from jegs/summit.....
Old 08-30-2004, 01:04 AM
Ferocity02's Avatar
Havent seen a high flow pump either, only the ported ones. My TSP one gets up to 80psi at WOT though.
Old 08-30-2004, 01:16 AM
Gimp98TNT's Avatar
I did a search and I came up with the part #m295. I found it at summit for 87.99 not too bad at all. Here's the link to it.
http://store.summitracing.com/defaul...ch%2Easp&N=100
just select melling from the manufactures list and part number M295.
