Intake manifold gaskets.....
Old 09-01-2004, 02:41 PM
rally2247's Avatar
Default Intake manifold gaskets.....
I had to remove my driver's side cylinder head because one of my spark plug holes was stripped. Now, when I picked up my cylinder heads from the machine shop today, they told me I needed to buy new intake manifold gaskets because you couldn't reuse the old ones. Is this true? Because these little rubber gaskets for the intake manifold cost $70. If I don't need them, please let me know so I can return them.
Old 09-01-2004, 02:45 PM
Squintz Palladoris's Avatar
your old ones should be fine.
Brad
Old 09-01-2004, 03:26 PM
rally2247's Avatar
So, was this guy after just to screw me over? Or is it typically suggested to replace these things?
Old 09-01-2004, 03:28 PM
cyphur's Avatar
you're kiddin me? they cost $70??? for some reason i thought i remember seein a set layin around my room....****. i could use that kind of money.
Old 09-01-2004, 03:34 PM
rally2247's Avatar
Apparently that's GM price at least. But, I'm going to return them anyways, because if I really need them, I'm sure I can find them cheaper somewhere else.
Old 09-01-2004, 06:16 PM
I am willing to bet he did not know that the LS1 uses a rubber o-ring around each port instead of a paper gasket like a Small Block Chevy.
Double check them to make sure they have not shrunk or become deformed anywhere. They should be good to go.
Brad
Old 09-01-2004, 06:36 PM
LS1TECH Sponsor
badpewter-z's Avatar
they are reusable for the most part as long as there still in decent shape.
yes gm's prices are outrageous for them too, not sure if there on the aftermarket yet though
Old 09-12-2004, 01:09 AM
99SLOWC5's Avatar
Whats the part number for those intake manifold gaskets?
NEED A SET ASAP
JEFF
Old 09-12-2004, 03:33 AM
PREDATOR-Z's Avatar
Well, as said above, but word of caution!! Don't take it for granted that they are reusable. Inspect them very carefully because they are the major cause of vacuum leaks, besides broken nipple in the back of intake.
