Freeze Plug
Old 09-02-2004, 02:13 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Freeze Plug
Can a freeze plug from the 2001 LS1 be used with a 2001+ LQ4 block?
Old 09-02-2004, 03:47 PM
blkZ28spt's Avatar
What kind of freeze plug? Is there an LS1 specific freeze plug? Only thing I am away of using a freeze plug for is the EGR hole in the intake manifold on older LS1's.
Old 09-02-2004, 03:57 PM
ls1290's Avatar
Let me try again.... I am referring to the threaded hole in the side of the block by one of the cylinders.
Old 09-04-2004, 08:14 AM
Uthinkso's Avatar
There are 4 threaded holes in the LS1-LQ4 blocks. Two are for oil, the other two are for coolant. They are all universal from one block to another, just make sure you use a dab of teflon paste or pipe dope to make sure you get a good seal.
Old 09-07-2004, 07:36 AM
ls1290's Avatar
Cool Thanks for the info.
Old 09-14-2004, 02:11 PM
ls1290's Avatar
Are these the part numbers:
oil plugs: 21007339
coolant plugs: 12553191
Are there any other plugs needed for a GM bare block?
TIA.
Old 09-15-2004, 10:40 AM
ls1290's Avatar
oil plugs: 21007339
TIA.
Anyone.......
Quick Reply: Freeze Plug
