? About swapping Valves
Might have bent a Valve on head,symptom it has been having this light tapping noise for awhile.Im pretty sure its a bent valve or a faulty lifter.Is there any special procedure in replacing the valves?I would like to install Ls6 Valves but was uncertain if its a straight swap.
You could do a compression test to see if it is a bent valve,should be way off.I believe you can swap in the ls6 valves but have heard some say they are longer,I"m not sure?
