pre-load on hyd. lifters
Old 03-30-2003, 11:24 PM
Brian98's Avatar
Default pre-load on hyd. lifters
Heres my concern.....i was putting the engine back together,,,and when it came time to check pushrod lenght this is what happened
cam 222/224/566/568 112
heads are milled .025
The lifters are suppose to have .020-.040 of pre-load mine had about .100-.120.
so to me i will have to go with shorter pushrods--7.30-7.35's
I've notice there is not alot of talk about pre-load on the lifters...r you guys just putting the stock 7.40's back in with out checking pre-load???
Or am i to concerned with this matter. I'm going to talk to comp cams tomorrow about this but in there directions they make it VERY CLEAR. So what r you guys doing????
Old 03-31-2003, 03:02 AM
jmX
jmX's Avatar
Default Re: pre-load on hyd. lifters
Are you using stock lifters or comp-r's? The stock ones are fine with all sorts of preload it seems. The comp-r's want 20 thousanths or so (half a turn on the bolt). Shorter pushrods are one way to get what you are looking for.
I'm running 10 thousanths preload on my setup, 0.030" milled heads, 7.35" pushrods.
Old 03-31-2003, 06:58 AM
LS1Tech Sponsor
Slowhawk's Avatar
I had the same preload you are getting,so I installed the 7.350 and thay work very good.
Old 03-31-2003, 08:53 PM
Brian98's Avatar
jmx----
I running stock lifters....You say your putting preload in the lifter by turning the bolt after 22lbft.??? You really should have the pre-load at 22lbft. if i'm understanding it correctly.
I did by the 7.35's tonight but at the same time i'm hit the MAX preload with this and if i go with the 7.30's i would have to shimm....
Slowhawk....you were getting the same numbers...thats great to hear <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" /> I thought maybe i was the only one..I think they come from the factory with the wrong pre-load or something. If i do the math----hear me out-- my new cam's base circle is .074 smaller than my stock one...so cut that in half is about .037 and then subtract my milled head amount .025 i should have come up with .012 to play with..meaning i should have to buy a larger pushrod not a shorter one...but all in all the reading i'm getting now says i need to go shorter...
Old 03-31-2003, 08:56 PM
Brian98's Avatar
jmx--what cam r you running in that cam (the one with the .030 milled heads???)
