check engine light after rocker arms
Old 09-06-2004, 06:14 PM
cbota's Avatar
Default check engine light after rocker arms
Does anyone know why the engine light come on after I installed the slp 1.85 rocker arms, the code is p0300 (engine misfire) It seems to be running a little rougher, I checked the wires and coils and they seem ok. It seems it runs rougher at idle and alittle louder. Any help would be appreciated.
Old 09-06-2004, 06:32 PM
ss rally red's Avatar
Most probable, with the increased ratio of the rocker arms you have in all practical purposes installed a larger camshaft and that within itself will cause P0300 random misfire without tuning to desenitive the stock parameters.
Old 09-06-2004, 09:36 PM
P Mack's Avatar
Did you check the preload when you put in the rocker arms?
Old 09-07-2004, 05:40 AM
cbota's Avatar
These are non adjustable, torque to 22 to 24 lbs. Thanks
