Anyone hear this type of noise at half throttle?
Old 09-08-2004, 01:18 PM
WICKED SS's Avatar
Question Anyone hear this type of noise at half throttle?
The reason why I am posting this here is it could be internal engine related
I just picked up a 98z28 and it has been tuned with ls1edit. It has heads/224 cam, stall (A4)
and it was running fine, then I take it to get smoged and ever since then the SES light cam on. But the weird part is it sounds like it pinging but louder at only half throttle? I had someone check it out and he says I am running a little rich. So I am confused on what this could be. Also how do you know when your 02's are bad?
thanks
Old 09-08-2004, 02:43 PM
Another_User's Avatar
thanks
Sounds like something is causing real knock. Was the tuner a respectable tuner, or did some joker just throw a bad tune in there? How long did you have it before this problem started? If your O2s were bad it would probably run like crap all the time.
Old 09-08-2004, 03:58 PM
WICKED SS's Avatar
the car was tuned by 2 good tuners. The car runs strong so I think the 02's are ok. I just talked to the previous owner of the car and he said
Between the two of them they were able to get more
horsepower out of the head/cam job, but neither of them could
completely
eliminate the detonation at tip-in.
So what could cause detonation at half throttle?
Old 09-08-2004, 06:37 PM
I don't know. I think we would have to see the tune. Or at least a good log of what the sensors see when you get knock.
