New valve sprins w/ stock motor?
Old 09-14-2004, 09:50 PM
TeamZ's Avatar
Default New valve sprins w/ stock motor?
Im looking at replacing my valve springs.. I got about 90,000 miles on my stock valve springs. below is a list of what I got so far. Would I have any probs w/ everthing else being stock. I was thinking about going w/ the patriot gold duals w/ titanium retainers.. Unless their is something out their better. awile back I dynoed at 306.02 hp. I have been told that if my valve springs wouldnt have had so many miles I would have dynoed higher. With new after market valve springs about what would it dyno at?
Old 09-14-2004, 10:10 PM
luv2spd's Avatar
The only way it would change your dyno would be if you were getting valve float before. If you're going to change springs, why not just put in a cam? If you don't plan on getting a very big cam or sticking with the stock cam, patriot golds are overkill.
Old 09-14-2004, 10:11 PM
guadofreak's Avatar
if you are just gonna do springs and nothing more you do NOT need anything near a dual springs. 918's at max but even then IMO they are overkill. Unless you plan on changing cams in the near future.
