check for bent valve,head off
Old 09-15-2004, 05:25 PM
redbandit98's Avatar
Default check for bent valve,head off
whats the easiest way to check for bent valves if the head is off? i would rather not pull the valves out as i dont have a spring compressor here.. i can get one later just curious right now.. i have heard to see if they will hold liquid or something? any suggestions?
Old 09-15-2004, 08:42 PM
Hysteria's Avatar
Pour gasoline into the runners and check for it around the valve seats. It may bet a little wet but if it just runs out there you go, bent valve.
Old 09-15-2004, 09:06 PM
can you pour it into the other side of the head..as in the combustion chamber? will it sill have the same effect?
Old 09-15-2004, 09:09 PM
Hysteria's Avatar
Yes, you can just pour it into the combustion chamber and check intake and exhaust at the same time.
Old 09-15-2004, 09:21 PM
thanks
