Going with Futral cam! last minute decisions!
Old 09-18-2004, 06:29 PM
RollinSScamaro's Avatar
Default Going with Futral cam! last minute decisions!
Well i've been planning on going with the Futral F11- 228/230 .575/.595.. i heard a lot of people pushing around 400 RWHP with them on cam only set ups with about the same mods i have.. I was wondering what kind of LSA would be the best for the set up? are there any differences in gains or is it just sound? I was also trying to give myself a ball park idea of how i would run.. i ran a 12.784 at 110 with a 2.052 60ft time.. What kind of times would i be looking at with the F11 cam pushing around 400RWHP and actually getting the car to hook and run 1.7-1.9 60 ft times? I might be getting Hals 12 ways with the set up.. are high 11's out of the picture? What kind of shift points will i be looking at with this cam? 6500RPMS? or lower?
New set up will consist of: Futral cam(possible F11), double roller timing chain, patriot dual valve springs package, chrome moly pushrods, and an LS6 oil pump
Should i be going for a bigger cam? like a F13? I would like to stay with futral though.. I know i should use the search.. but there isn't too much about the F11's so if anyone could help me and get some ideas or maybe a different cam to run for better ET's i would greatly appreciate it! Thanks
Old 09-18-2004, 07:47 PM
Ragtop 99's Avatar
You getting some tuning? 112 LSA sould make for a pretty strong cam.
You want "bigger", just take 1 or 2 degrees out of the LSA. Try a 111 LSA with a 112 ICL or a 110 LSA with a 111 ICL.
Old 09-18-2004, 07:59 PM
PunkNPonys's Avatar
I am actually thinking about the same cam. I have about the same mods as you. My best time in good weather was 12.4 but now in these summer days i run 12.7s. I cant decide if i want to go bigger or not. I talked to Alan a few weeks ago and he told me the F11 would go perfect with my setup although he said i would be better off with some 3.73s, he also said that i should go with a 114 LSA for good street manners in my A4. Well let me know how it turns out for you or which cam you decide to go wtih.
Old 09-18-2004, 08:12 PM
BTL FED's Avatar
What did allan suggest for you? I would go with whatever he says, Allan is the man when it comes to cams. I told him about my setup, what my goals were and the next day he had a BAD solid roller speced out for me
Old 09-18-2004, 08:38 PM
ThackerSS's Avatar
Wait until Futurals new line of Cam's enter the market...
I just ordered one of their new line... 232/234 601/602 on a 112
My friend made 419 rwhp through a 12 bolt with 4.10's with their Ron Jeremy cam..
Old 09-18-2004, 08:43 PM
fattdaddyLS1's Avatar
Nice
Old 09-18-2004, 09:14 PM
ThackerSS's Avatar
Originally Posted by FattdaddyWS6
Nice
He posts here on the board under distortion_69,
The specs on the futural ron jeremy are 232/236 600/610 on a 111
It's a bad a cam
Old 09-18-2004, 10:18 PM
LSUxBlake's Avatar
I have the F11 and love it.
Old 09-18-2004, 10:21 PM
Shorty Director
VINCE's Avatar
It's a bad a cam
Thats bigger than my old FMS-9 cam... Make sure you guys take Allans advice on spring selection as well.
Old 09-19-2004, 10:33 AM
alright cool, sounds like i'll just have to call alan up and see what he recommends for me.. How much of a difference could 3.73 gears make compared to 3.42's? doesn't seem like the change would be that big of a difference.. Thanks for all the replys! i'll be calling allan on monday! Thanks
Old 09-19-2004, 11:20 AM
ThackerSS's Avatar
Trying to get everything out of your setup that you can? K, then go for 3.73's
Old 09-19-2004, 09:44 PM
what do you mean get everything out of my set up? tell him every mod? or change my set up? Will the 3.73's really make that big of a difference over 3.42's? Thanks
Old 09-20-2004, 01:47 AM
Retired Street Racer
Matt D's Avatar
would it be ok to run an f11 with a tci 4400 and 2.73 gears on mt drag radials?...don't mean to hijack your post, just want some quick input, thanks.
Old 09-20-2004, 05:54 AM
DEEZ98Z's Avatar
It depends on what your STR is on that converter (needs to be high)... other then that yeah it is fine.
I am also looking at getting the FM 11 cam.... I may have to call Alan again to get some info on his new cams
Old 09-20-2004, 06:00 AM
shaneSS's Avatar
Cant go wrong with a FUTRAL Grind. I love My F13 and have only had in in a few short days. I have it on a 112 +4 so tha ttorque is a little more streetable, however the cam still pulls stong through 6900!!!!!!!!!!!!!!! Im scared to take my stock bottom end that hi.
CHeers.
Old 09-20-2004, 10:28 AM
Kenny D's Avatar
Just call them and ask them. They are Straight up people and will tell you exactly what you need for your set-up. I went with the f13 cam and with stage 2 Ls1 heads my auto made 421hp
Old 09-20-2004, 10:43 AM
DEEZ98Z's Avatar
I was looking at the FM 13 aswell.... he recomended the FM 11 cam for my needs and set up. Was that locked or unlocked?
Old 09-20-2004, 10:51 AM
Kenny D's Avatar
Locked. Im going soon to redyno. These were the numbers after 6 pulls on the mustang and 5 on the dynojet. The mustang dyno calculations were about 425 unlocked. But i think the car was just way to hot. 17x11's on the back doesnt help either. Rims weight 60pounds with tires a piece. Times werent bad for 3650 race weight.
Old 09-20-2004, 10:54 AM
93Polo's Avatar
I like my F11 112+4 but it drives so well I almost wish I had gone with a F13.
Great cams.
Old 09-20-2004, 02:48 PM
Matt D's Avatar
the str on the 4400 is 2.78...more and more i think about it, i am going with the f13 or trex
Quick Reply: Going with Futral cam! last minute decisions!
