what is the correct stock pushrod lentgh
Old 09-24-2004, 07:13 AM
jason5's Avatar
Default what is the correct stock pushrod lentgh
what is the correct stock pushrod length on a ls1, i found out today that it was 7.318, and i always see people saying that they are 7.400, the reason i am wanting to know i am rebulind my motor and and i got the comp 222/224 568/568 112 cam and ls1 heads ported and milled .035, with yella terra 1.7 rockers, and i'm trying to see if i need to go with a shorter pushrod, so i need to know the correct stock length
Old 09-24-2004, 08:22 AM
PREDATOR-Z's Avatar
Jason, you must have posted this 1/2 a dozen times.
Stock p-rod length is 7.380'
Now aftermarket cams have a slightly smaller base circle that is why we use 7.400 after market p-rods.
But you have milled your heads (.035) so 7.35 it is.
To make sure use a pushrod measurement tool.
