Need Help Fixing PCV system should be easy. Help
I was pulling off the driver side valve cover and got all the bolts off. I noticed the Rubber elbow coming off the Black plastic peice of the valve cover looked like it was in rough shape. I ended up ripping the rubber elbow for the PCV system. What do I need to do to fix it? Do I just replace the rubber piece. It feels like there is more imprtant stuff in the larger size hose that goes behind the motor. Please help. Thanks.
