gm part # needed
Old 10-06-2004, 09:37 AM
98Blubrd's Avatar
Default gm part # needed
I need the part number for the PCV hose that goes from the drivers side valve cover to the passanger side valve cover. Thanks.
Old 10-06-2004, 10:28 AM
Hysteria's Avatar
12556454 is the part number, probably $7 or so at the local dealer.
Old 10-06-2004, 10:36 AM
98Blubrd's Avatar
thanks does it come with that insulation stuff on it?
Old 10-06-2004, 11:47 AM
Hysteria's Avatar
I do not know.
Old 10-06-2004, 06:23 PM
MM98's Avatar
That's not the right # for his car.... He's got a 98 & needs part#12560692.... It's going to be one assembly containing the hose from the driverside valve cover to the passengerside cover along with the hose that houses the pcv up to the intake... They are not cheap, like around $100 & the fitting on the valve cover that the hose plugs into is not included, part#12557672 if you need it also... On the 99 & above cars you can get the hoses seperate because of the design change of the valve covers.
Mike
Old 10-07-2004, 08:16 AM
98Blubrd's Avatar
the only part that tore was the rubber elbow peice that goes into the driver side valve cover. can i just rig it up with another elbow. I just want to rig it to work so I can run the car and see if my 1st cylinder is not missing. If it isnt then i will buy the hose if it is i got bigger problems to worry about.
Old 10-07-2004, 10:13 AM
SidewayzOZ's Avatar
I think you have to buy the stupid elbow with the valvecover
Mine broke too, so I just pulled some hose off an old mustang and used it.
Old 10-07-2004, 10:56 AM
hourang's Avatar
just get some hose from your local hardware store, bring the broken hose with you for size.
Quick Reply: gm part # needed
