LS6, 6.0 or AFR for FI stroker?
Old 10-26-2004, 07:53 AM
jermstyle's Avatar
Default LS6, 6.0 or AFR for FI stroker?
I’m looking to buy some heads for my N/A 346 that I could use next year on my stroker engine. The compression would be down while they’re on the 346, but it shouldn’t be too bad.
Thanks!
Old 10-26-2004, 03:19 PM
black_z's Avatar
Since your stroker wont be built til next year I would save your money until we get some clear independent AFR 225 results.
Old 10-26-2004, 03:46 PM
conan's Avatar
I just got my 6.0L heads from MTI today For my Ati Plans in the summer of 05 they are relly nice pieces and not as mutch $$ as the afr's. But like blackz said wait you'll be kicking your self when you have to repeat every thing you just did when the new motor comes. Also i am under the impression I will be losing hp with these heads untill the blower comes.
Old 10-26-2004, 10:44 PM
2000 Tran Zam's Avatar
afr heads will definately hold more pressure then the other heads due to the thicker walls from what i understand. wait for some results from the 225's, and if they do not turn out to be the best, then go with the 205's.
Old 10-27-2004, 08:41 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I am extremely happy with my TEA 6.0L Stage III FI heads. They are absolutely beautiful They are also O-ringed. Brent from TEA said that the heads with ASP head studs should hold 15 psi without any problems.
Old 10-27-2004, 08:44 AM
SAM98WS6's Avatar
get ls6 heads...why take a chance...proven *** kickers...
