Trex V.2 Cam
Old 10-28-2004, 07:16 AM
sevanseriesta's Avatar
Default Trex V.2 Cam
I just bought this new Cam and I want to install it bad.
What I want to know is if I buy the Comp Cams 921's the dual spring capable for lift up to .650 do I have to machine the heads?
Also Can anyone give me an Idea of what there power gains were?
Old 10-28-2004, 08:03 AM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
If the heads are not milled you can just slide the cam in. Piston notching is not needed.
Old 10-28-2004, 10:54 AM
smithsc's Avatar
No!
I have the same setup on a Z06 with LS6 stock heads and gasket. No machine work required for the COMP 921 springs or flycutting of the pistons.
Steve
Old 10-28-2004, 06:38 PM
Hey thanks for the info what kinda power gains did you get
