line boring the 6.0 ? can it be done?
Can you line bore the 6.0 and if so how much material can be removed without getting to close to the camshaft when running a 4 inch stroke crank with 6.125 rods. Any help would be greatly appreciated. I just found a long block and when I went to inspect before buying I found out the numnuts that had the motor before must not have known to look at his oil pressure guage. Thanks again.
<small>[ April 09, 2003, 11:05 PM: Message edited by: DEVIATE ]</small>
