highest flow oil cooler?
Old 11-14-2004, 09:33 PM
2001CamaroGuy's Avatar
Default highest flow oil cooler?
what company (Earl's, Perma-Cool, etc...) makes the highest flow oil coolers?
It looks like there are three styles of oil coolers.....
- a "Headered" style where you have on tube on one side that splits to 3 or more large tubes that then pass from one side to the other and then rejoins in another single tube
- you have a single line that crisscrosses back and forth across the air flow path
- you have a main tank that splits to a bunch of small "flat" tubes that go from one side to the other and then join back to another tank
is one a higher flow setup than the others?
