Thrust bearing Questions?
Old 11-19-2004, 06:00 PM
11 Second Truck Club
LS1BirdDRG's Avatar
Default Thrust bearing Questions?
Hey all, I did my own cam install early this year. I have about 4k miles or so on the car since and occasionally I hear a sound like something is loose and rattling and I can't find it. It's not loud but it's definately there sometimes but only at certain rpm's right off idle. (maybe between 1000 & 2000 rpms.)
I did have problems installing the pully before I found a longer bolt. I did tap the pully on some with a rubber mallet. I also used a hammer & block of wood but there wasn't much room to hit very hard. (yes, still dumb)
I'm curious how, if possible, is it to check the thrust bearing to see if maybe it was damaged? (without disassembling of course) What are the symptoms of a damaged thrust bearing?
I don't have any problems with the car and just did the clutch so it's nothing in there.
Thanks, any help appreciated.
Old 11-19-2004, 06:03 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
More likely your exhaust.
If the thrust bearing goes the crank will move around and the crank sensor might go out of range, and your car might stall out.
Old 11-19-2004, 06:15 PM
LS1BirdDRG's Avatar
Thanks, I've been over the exhaust but maybe it could be. I hope so, I'm doing TSP true duals next week so hopefully that's it.
I just had a bad feeling since I was researching the March pully I ordered rescently and saw all the posts about people saying not to use a mallet on the pully.
Old 11-19-2004, 06:18 PM
LS1Tech Co-Founder
You just used a mallet to get it started right? As long as you didn't have veins popping out of you forehead I'm sure it's okay.
Old 11-20-2004, 03:23 AM
LS1BirdDRG's Avatar
I'm gonna keep my fingers crossed, because the more I think back, the more I remember beating on it considerably.
I am installing my new u/d pulley this morning, anything I could check for peace of mind? Thanks for the info.
Old 11-20-2004, 06:29 AM
PREDATOR-Z's Avatar
We should make this a sticky:
DO NOT USE IMPACT WRENCH AND DO NOT BEAT ON THE PULLEY TO INSTALL
