Which Stealth Cam? Heads?
Old 12-12-2004, 10:27 PM
02WS6Bird's Avatar
Default Which Stealth Cam? Heads?
SS1 or SS2 for a full bolton car, auto or manual...will not run nitrous
want it to sound pretty much like stock with Lt's but mayb slgihtly louder. Want to put down best numbers possible have a good low end as well as top end and pull hard all throughout.
What RPM do these max out at? how high should the rev limiter be raised?
What heads should be used with what valvetrain mods?
Old 12-13-2004, 01:41 AM
goober35's Avatar
1290 post and you dont know about heads or cams. There is this button at the top do a search. Just type in sleeper cam. THink you will pull up 100+ threads.
Old 12-13-2004, 01:45 AM
jrp
SN95 Director
jrp's Avatar
you cant have your cake and eat it too, some compromises must be made.
Old 12-16-2004, 09:38 PM
02WS6Bird's Avatar
i've done a search and i havent seen any1 compare the two throughouly enough to get info i need. thats why i ask here. I've been told that the reverse split is ideal fro nitrous but i dont kno much about this part. i've been learning about things other than cams for quite some time
Old 12-17-2004, 12:28 AM
PREDATOR-Z's Avatar
Stealth II here.
404rwhp/383rwtq
Bolt ons, VIG 3200, 3.73 stock rear.
Has to rev at least till 6400 will carry till 6700 or so. I shift at 6600.
I hit the 10's last week with a 2 stage 200 shot dry.
Old 12-18-2004, 09:52 AM
PewterC5-2000's Avatar
MTI Stealth-I here...see mods/dyno below....
Old 12-18-2004, 01:38 PM
02WS6Bird's Avatar
sounds good keep em coming...i may just put a poll in here as well for all to see/judge
