What is the biggest cam I can run with 59cc heads?
its not the cc its the valve size as long as they havent been milled...call patriot and see what they say or call tsp they could tell you. i'd guess a 23x with .59x lift is about the biggest you can get away with.
nate
nate
i asked them that same question when i bought my heads, and they told me that since the heads aren't milled, it's just some filling in the conbustion chamber you could run what ever sise cam you want. so i was told
What size valves did you order? The biggest that I know of is the LG G5X2 112LSA and the G5X3 on a 114LSA. With the G5X3 114LSA you still should clay it to check PV clearance. I'm going with the G5X2 112 or, if it will work, the new TSP 233/239.
