A few pics from my build
Originally Posted by CAT3
A carpeted garage with desktop pc and dresser! Damn thats sweet!
Specs on the build are: APE 382 shortblock, Callies crank, Eagle rods, Diamond pistons w/-7cc reliefs, TEA/AFR Stage 2.5 Judson heads w/nitrous exaust port milled .024 to 62cc's, FAST 90/90 port matched by me, Comp XE-R 244/248 .612/.615 111+2 spec'd by me, Morel lifters, ARP studs all the way through, Meziere WP, Speed Inc. fuel system with 8- feed and 6- return, Bosch 420 pump, sumped 98 model tank, Delphi injectors, TNT F2 kit w/200 shot, 11:2:1 compression, and hopefully a good speed density tune by Futral. It'll go to the ground through a Spec Stage 3 carbon/ceramic clutch, my T-56, Spohn indedtructable drive shaft, and a Moser 12-bolt w/4.10's for the time being. I'm sure more will come to me in a while......
Your no where near done buying parts. Looks good. Wish my block was as pritty as yours.
P.S. Does that cam leve the vavles closed enuff to fire. LOL that is a ******* sick *** cam.
