Stock Heads & TSP 231/237 with 7.350 Pushrods?
Im going to be getting a TSP 231/237 and probally be running the stock heads for ahwile. And I already have a set of comp cams pushrods but they are 7.350". Will these be ok with stock heads and this cam?
Originally Posted by Slowhawk
You'll have to check the lifter preload to make sure.I like around .080 preload.If the pushrod is too short you can break a lifter.
Originally Posted by hellbents10
I think you will want 7.400.
you won't travel into 7.350 territory til after you shave your heads. there are always a few people tryin to get rid of 7.4's, needing 7.350's. you might luck out and find on in the FS or PW sections!! good luck.
