Will Crane Have Its New Shaft Mount Rocker For LS1 Heads
Crane has a new shaft mount rocker for SBC heads. It looks interesting.
Has any one talked to them about an LS1 version? Here is a link:http://www.cranecams.com/?show=shaftMount
There is also a PowerPoint presentation with other valve train info. It is mainly about their 'Quick Lift': http://www.cranecams.com/pdf/04qlps.pdf
Their 'Quick Lift' doesn't make much sense to me. They claim 6 or so degrees bigger at .200". However it is not much bigger above that. No dyno numbers.
However the new shafts look like they may be a real advantage.
David
David
http://www.vincihighperformance.com/...RTSPARENT.HTML here's an explaination of the quick lift or accelerated lift technology.
Yes...but what about the shafts? The PowerPoint has much more information on the quick lift. However, I'm not sure it works in range (primarily below .1" cam lift) to have much affect on overall flow.
