what length pushrod?
Old 01-28-2005, 03:08 PM
CATCH ME's Avatar
Default what length pushrod?
if i am running a 1.7 non-adjustable jesel shaft mount rocker and a 228/224 .591/.583 112lsa cam what length pushrod should i run. i think i have 7.400 comp cromoly rods now...just want to make sure to run the right length...help
Old 01-28-2005, 03:10 PM
DAPSUPRSLO's Avatar
If you are running the stock lifters or stock replacement lifters then the 7.4" should be fine unless you have significantly cut the heads.
Old 01-28-2005, 03:52 PM
CATCH ME's Avatar
thanks!
Old 01-28-2005, 03:54 PM
Viper's Avatar
LS1Tech 20 Year Member
If you're extremely curious on the exact length:
http://www.holley.com/HiOctn/TechSer...ECVTTech1.html
