Big cam in Stage III heads..
Old 02-01-2005, 02:21 PM
BAD FNZ's Avatar
Default Big cam in Stage III heads..
I was looking around for custom grinded cams for a nitrous car and I cam across a TSP grinded 237/242 .602/.611 @113 cam. I was looking to put it in a car that has Stage III 6.0l heads, 2.02/1.60 valves, dual spring, milled to 11:1 compression. My question is; would I run into problems with clearence with that much lift. The heads were decked for a much higher compression so what would be the highest lift I could go with?
Old 02-01-2005, 04:02 PM
BAD FNZ's Avatar
No one knows?
Old 02-02-2005, 02:51 PM
BAD FNZ's Avatar
ttt..
Old 02-02-2005, 03:25 PM
jrp
SN95 Director
jrp's Avatar
assuming a stock gasket, 6.0 heads would need to me milled ~.070 for 11.1 CR. so ya, you'll need to flycut to use the MS3
Old 02-03-2005, 01:50 PM
BAD FNZ's Avatar
So with out having to flycut, what would be the biggest cam I could go with.. would the TSP torquer cam (233/233 .589/.589 112 LSA) be more reasonable, or would that still be to big..
