317 Heads, Worth it?
Old 02-01-2005, 08:49 PM
1jfuddle's Avatar
Default 317 Heads, Worth it?
I am considering a set of aluminum truck heads. Casting 317 using the LS6 design. I've heard conflicting ideas on using these heads. What are your thoughts? If I don't do any work to them, what valve size do I want?
Also, will they work on a 98 block?
Old 02-01-2005, 09:15 PM
INVISIBLEZ's Avatar
They're not worth it if you don't port them. You'd do better to go with a 241 casting head. 317's are for bigger 6.0 engines, unless milled and ported for a 346 c.i. engine. You would'nt have any compression, so you'd hurt yourself instead of help yourself.
Old 02-01-2005, 09:24 PM
BrentB@TEA's Avatar
they also do not flow as well on the smaller 3.9 bore. Your best bet is a set of "TRUE" ported LS6 heads followed by ported 5.3 truck heads.
Old 02-01-2005, 11:39 PM
Zedzag's Avatar
Brent, how well do 317 heads flow on the larger 4.0 bore ? Would a 6.0 see the same gains with a cam as a 5.7 does?
Old 02-02-2005, 10:58 AM
1jfuddle's Avatar
As far as the flow, I was under the impression that they had the basic LS6 design as far as intake and exhaust with just a bigger combustion chamber. Is that wrong? If I had them milled, would that make it more worth it? I can get a STEAL on a set of these heads ($300), am I just dreaming that these would be worth it? Should I just spend my money on ported ls6 heads, or is the price good enough on these that I should do it?
BTW, it is a nitrous car and I plan on spraying a 200 shot.
Old 02-02-2005, 01:12 PM
98Raptor's Avatar
Go with ported 5.3 heads.
Old 02-02-2005, 08:18 PM
ktmrider's Avatar
Only real advantage to using them on your LS1 is to lower the compression for FI. Otherwise spend the money elsewhere. BTW, tho, awesome price on those #317's!
