How much P/V clearance is adequate before flycutting on a M6 car?
Old 02-07-2005, 11:20 AM
eb02z06's Avatar
Default How much P/V clearance is adequate before flycutting on a M6 car?
I did a search but could not find anything. Just wondering what you guys have found is adequate piston valve clearance before you need to flycut. According to Crane they suggest clearance should be no less than .080 on the intake and .100 on the exhaust? This is on a M6 car where misshifts and overrevs are alot more common than on a A4. Thanks guys!
Old 02-07-2005, 11:30 AM
1fastWS6's Avatar
Thats what I used when I installed and degreed my cam.
Old 02-07-2005, 05:32 PM
smask04C5's Avatar
.080 intake and .100 exhaust is fine
Old 02-07-2005, 05:51 PM
LS1Tech Sponsor
Slowhawk's Avatar
For the right springs that will keep valve float to the absolute minimum
Old 02-07-2005, 06:04 PM
m6z
m6z's Avatar
so u wouldn't hit a piston if u missed a gear w/.080 &.100? such as 3rd to 2nd. with the right springs ofcourse.
Old 02-07-2005, 06:07 PM
smask04C5's Avatar
nope, with correct valvetrain these clearances are more than adequate even for a manual
