6.0L Aluminum Heads
6.0L Aluminum Heads
i was wondering i will soon be installing the TSP 233/239 into my car and also the PRC dual valvesprings kit. i found some heads for sale Casting #317 Aluminum 6.0L Heads brand new. will my car gain anything or are those meant for a different application. thanks
-Joel
-Joel
Your 6.0 heads.
Originally Posted by stone4779
How much would they have to be milled to bring the CR back to 10:1 with stock GM head gasket on a 6.0L block?
Your 6.0 block will have 10:1 compression with 317 heads. Those heads are used on the Cadillac Escalade which has 10:1 compression. They are also used on GM trucks.The only difference is the Caddy has flat top pistons, and the truck has dished pistons which yield 9.4:1 compression.The 317 head has
a 71.06cc chamber, and when milled .030, which would yield a 67.66 cc chamber. That is the stock chamber of an LS1. 317 heads are also the same heads that several companies sell as LS6 style heads after machining.
